Bias Bandwidth
Bias Bandwidth
As far as I understand the Bias Bandwidth is a parameter that can be changed to avoid high or low lighting fluctuations, but I will also affects the bandwidth of the camera, which is restrictive to the maximum events per sec that can be processed. That is why I would like to understand that parameters. Normally to say if there are high or low lighting fluctuations you measure the frequency in Hz, so I suppose that there should be some relation between the numbers in the range to adjust Bias Bandwidth bias_fo and bias_hpf and Hz.
Could you clarify what does that numbers mean for the EVK 2 or if they have some units or which variables are related to define those numbers and how. In that way I will be able to understand how to set it for good results.
Thanks for your answer,
Luisa Maya.
