Dataset Structure for YOLOv8 Training Issue:
I'm encountering problems while training a YOLOv8 model using a custom dataset structure. I've followed the steps outlined in Prophesee YOLOv8 tutorial and used the Prophesee ML labeling tool.
I am getting the following error:
ValueError: num_samples should be a positive integer value, but got num_samples=0
My dataset looks like this:
Dataset:
   ---Train
        ---yyy.h5
        ---yyy_bbox.npy
   ---Val
        ---zzz.h5
        ---zzz_bbox.npy
   ---data.yaml
I'd appreciate any help with formatting the dataset correctly. Are there any suggestions or changes you could recommend?
