Dear community,
Thank you for reading.
I am currently working with two EVK4 camera synchronized with the sync module of the SDK. I recorded some synchronized raw and I wanted to play it back real-time, and still synchronized. I cannot use the sync module for replayed data, as specified in the sdk:
"You cannot run this sample from a pre-recorded RAW file, as the synchronization only works with live camera. RAW files recorded with synchronized cameras will have synchronized timestamps, but can be played separately using any available RAW player."
Still, replay the data in a synchronized fashion is mandatory for me to reproduce the results. For now, I can only play them back using the camera class of the driver module with hints configured with the realtime, but somehow the two event streams never launch at the same moment, and I do not succeed to find a simple solution to this apparently classic issue, but maybe it is not?
Do you have any clue/simple solution to handle this?
Thank you very much!
Best,
Maxime
