I'm trying to measure the electro-optical caracteristics of my GENX320 sensor in the same conditions as the datasheet indicates. For the light source, the datasheet indicates :
When you look at the wavelength associated to this color temperature with Wien's displacement law :
You get for a color temperature of 3000 K : 966 nm
If you look at the quantum efficiency of the sensor from the datasheet :
At that wavelength, the QE isn't at its maximum.
Why so ? Wouldn't it have been better to use a source at 5700K to be at around the QE's peak ?
I'd be curious also to know the reference of the light source that you've used ?
Cheers,
Michael
