Hi!
First, I wanted to point out a minor error in the KV260 Starter Kit Manual. In "Edit kria applications", the suggested command is petalinux-devtool modify metavision_x.x.x. However, petalinux-devtool modify takes the root recipe, without the version.
Other than that, I found out that running petalinux-devtool modify metavision fails. An error is encountered while patching but the log file it points to does not exist. Moreover, I find it strange that petalinux-build works without problems.
Thanks for your support!
