IMX636 event rate discrepancy between MIPI and USB
When capturing a scene with the IMX636 via MIPI on the KV260 evaluation kit, we achieve a data rate of approximately 130MB/s. However the event rate is only around 6.5 MEvt/s. When capturing the same scene using the USB version (EVK4), we see around 46 MEvt/s. What is the reason for this discrepancy, and is there a way to correct it? While a similar amount of data is captured on both systems, only a small fraction of events seem to be recognized on the KV260.
