The EVK4 camera with an USB3 cable is rated for hundreds of MB/s of data transfer; however, when running the EVK4 camera in a rapidly changing environment (where almost all pixels across the camera's resolution are changing) for around 10 seconds, an .es file of only magnitude 250KB is returned.
Furthermore, when using the camera to capture an LED with signal frequencies 1000Hz and above, the plotted EV/s graph doesn't return the expected peaks and periods.
This machine has already been tuned to near optimal settings for this particular setup and has been confirmed to be able to identify the peaks of a signal with frequencies of 500Hz and below.
