I'm working on an application using the Kria KV260 starter kit and GenX320 sensor. We have the simulation IP working correctly and producing events which correspond which is great but I have two questions:
The test pattern appears to be a headerless RAW file in IMX636 format (i.e. 1280x720). Are there any RAW file examples available for GenX320 (just a spinning disk or something would be ideal)? There is an HDF5 example in https://docs.prophesee.ai/stable/datasets.html but there doesn't seem to be a tool for converting from hdf5 to raw.
