I'm trying to understand how the EVT 2.1 format works on GENX320. In order to do so, I generated 2 light edges (positive then negative) with a contrast well above the threshold value. The generated .RAW file should contain data with a sequence of ON events followed by some OFF events. My ROI is 320x320. I opened the .RAW file with a hexadecimal editor software, but I can't seem to understand how the data is encoded. There seems to only be"cd off events" and "Timer high bits" (assuming that the data is stored in little endian)? I have attached the .RAW file to this message if you want to check it out.
Kind regards,
Michael
