Hi All
I'm trying to use four EVT3 in one PC.
I use metavison studio version 4.5 to open four EVT3 camera.
Sometimes it will occur NonMonotonicTimeHigh error, it happened randomly not always in the same camera.
I found this document from prophesee website, it recommend to reduce event rate.
So I try to tune focus and aperture of camera lens to make every camera event rate is almost the same.
And I suppose event rate is not too high, but this NonMonotonicTimeHigh error still happened.
Does anyone also encounter this error ,could you please kindly give me some advice or solution to solve this problem.
Thank you
