GenericProducerAlgorithm::is_done() does not change status automatically
I use Metavision::camera for reading from a file or a camera, and  GenericProducerAlgorithm to get events (in the same way as in the metavision_player example)
Now I want to close the application when all events was read from a file and processed by GenericProducerAlgorithm.
camera::is_running() works as I expects, but not all events are processed at the time of camera::is_running() become false.
I would expect, that GenericProducerAlgorithm::is_done() or GenericProducerAlgorithm::is_source_done() would chage status some time after camera::is_running(), because events could be in the queue of the producer.
However, both functions are never become true.
Am I using the GenericProducerAlgorithm wrong?
there is the parameters of GenericProducerAlgorithm: I have the first 3 to make sure no events will be skipped when reading from file, and the last one, I think, responsible for latest_event_timestamp_available() become -1 after around 20 seconds of the end of file.
    allow_drop_when_overfilled": false,
    max_duration_stored_ms": 100'000'000,
    max_evps": 15'000'000,
    "timeout_ms": 20'000,
there is a log of processing file around 300 seconds:
startup camera_.is_running() genericProducer_->is_done() genericProducer_->is_source_done() genericProducer_->latest_event_timestamp_available();
280 1 0 0 279582864
290 1 0 0 289584041
300 1 0 0 299587656
310 0 0 0 300127454
320 0 0 0 300127454
330 0 0 0 -1
340 0 0 0 -1
