HDF5 & Raw file play time differnece
If I "simply" convert the Raw file into an HDF5 file without any cutting and turn these two on with the metavision player, I could see that the "total playtime" changes, and the "position of objects in both files at the same time zone" changes as in the picture I attached above. This is the problem for me. If you know what causes this problem and how it works, could you let me know?
(If the time step where the event was recorded would be the same whether it was Raw or HDF5, I'm confused as to why.)
