Issues of EVT2 RAW File encoder
Hi, when I used metavision_evt2_raw_file_encoder to encode a CSV file into an EVT2 format RAW file, I found that the timestamps of the events in the RAW file were different from that in the original CSV file. There is a difference of tens of microseconds between them. Is it due to the encoding method of EVT2 format? Are there any ways to eliminate the timestamp difference between them?
Thank you very much for your help.
