Hi!
When I launch this example in VMware Virtual Machine - Ubuntu OS, I receive this error:
"[HAL][ERROR] Error while opening from plugin: hal_plugin_gen31_evk3
[HAL][ERROR] Integrator: Prophesee
[HAL][ERROR] Device discovery: Metavision::TzCameraDiscovery
[HAL][ERROR] Failed with non Metavision HAL default exception:
[HAL][ERROR] LIBUSB_ERROR_TIMEOUT
[HAL][ERROR] Error while opening from plugin: hal_plugin_imx636_evk3
[HAL][ERROR] Error while opening from plugin: hal_plugin_gen41_evk3
Traceback (most recent call last):
File "/usr/share/metavision/sdk/core/python_samples/metavision_sdk_get_started/metavision_sdk_get_started.py", line 100, in <module>
main()
File "/usr/share/metavision/sdk/core/python_samples/metavision_sdk_get_started/metavision_sdk_get_started.py", line 40, in main
mv_iterator = EventsIterator(input_path=args.input_path, delta_t=1000)
File "/usr/lib/python3/dist-packages/metavision_core/event_io/events_iterator.py", line 71, in __init__
self._init_readers(input_path=input_path, **kwargs)
File "/usr/lib/python3/dist-packages/metavision_core/event_io/events_iterator.py", line 94, in _init_readers
self.reader = RawReaderBase(input_path, delta_t=self.delta_t, ev_count=self.n_events, **kwargs)
File "/usr/lib/python3/dist-packages/metavision_core/event_io/raw_reader.py", line 95, in __init__
self.reset()
File "/usr/lib/python3/dist-packages/metavision_core/event_io/raw_reader.py", line 188, in reset
self.device = initiate_device(self.path, do_time_shifting=self.do_time_shifting,
File "/usr/lib/python3/dist-packages/metavision_core/event_io/raw_reader.py", line 62, in initiate_device
raise OSError(f"Failed to open camera {path} !")
OSError: Failed to open camera !"
What I must do for solving this problem?
Thanks!
