Metavision HAL Exception Error 105000:
Greetings!
I wrote an application to configure and record Eventcameras. In this setup we are using an EVK4 with IMX636.
When changing the bias_diff_off to over around 120 the camera loses its connection and an Metavision HAL Exception Error 105000: is printed in the IDE.
 I am on SDK version 4.5.2 and doing the same in Metavision Studio works with no problems.
What could that be and how can I avoid this error?
Edit:
After investigating with log settings set on TRACE, I at lease found that it seems to be the poll thread shutting down. Further help would be great!
Thanks a lot
