Metavision studio crashes without error messages
Metavision Studio crashes immediately after start, even before the GUI appears. There is no error message produced and seemingly no logging output generated. I am using metavision SDK version 3.1 and a EVK2-4.1 with the latest firmware. Has anybody encountered this before or any suggestions how I could try to debug this?
Note: I am running all this inside a docker container based on nvidia/cuda:11.3. Other metavision GUI applications like metavision_player or metavision_viewer run without any problems.
I've attached the full output of metavision_platform_info to this issue, but here is already an excerpt with presumably the relevant/useful sections
####  DISTRIBUTION  ####
Linux 7C8FJF3 5.15.0-52-generic #58~20.04.1-Ubuntu SMP Thu Oct 13 13:09:46 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
####  OPENGL  ####
OpenGL vendor string: Mesa/X.org
OpenGL renderer string: llvmpipe (LLVM 12.0.0, 256 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 21.2.6
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.1 Mesa 21.2.6
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.2.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
####  VIRTUAL MACHINE  ####
sudo: dmidecode: command not found
Virtual Machine:              NO
Docker:                       YES
METAVISION SOFTWARE INFORMATION
####  INSTALLED SOFTWARE  ####
Version:                      3.1.0
####  INSTALLED PACKAGES - METAVISION  ####
Name                               Version   Architecture   Description
metavision-decoders-samples        3.1.0     amd64          Metavision samples on how to decode raw data
METAVISION SYSTEMS INFORMATION
####  SYSTEMS AVAILABLE  ####
# FOUND Prophesee GEN 4.1 HD #
Connection                    USB
EVKv2 Build Date              Tue Oct  5 20:01:55 2021
EVKv2 Release Version         1.6.0
EVKv2 Speed                   5000
Integrator                    Prophesee
Raw Formats                   EVT3
Sensor Info                   4.1
Serial                        ...
System Version                4.2.0
SystemID                      39
device0 compatible            treuzell,streamer
device0 name                  Treuzell kernel-side implementation
device1 VCS commit            0x1e4b001c
device1 build date            Wed Mar 10 11:59:07 2021
device1 compatible            psee,video
device1 name                  a0000000.zynq_processing_system_u_ps_m_axi_lite_o
device1 system ID             39
device1 version               4.2.0
