Multiple DVS synchronization (more than 1 slave)
Hello everyone,
Our team plans to synchronize more than one slave DVS (with one master and three slaves). We've followed the recommendations for multiple DVS synchronization, but during testing, we found that only one slave is precisely synced with the master, while the other two have delays.
My questions are:
Has anyone synchronized more than one slave DVS before?
Can you recommend an active booster circuit for synchronizing multiple DVS?
Will the USB connection from the DVS to the PC affect the synchronization process? For example, is there a difference between using a USB hub and a direct connection?
Thank you.
