Mv_iter stuck when no events occurred
I am using the Metavision recorder (
https://support.prophesee.ai/portal/en/kb/articles/how-to-record-data-with-metavision-recorder)
, and notice that when no events are received from the camera (For example, after use small roi and strict biases), the mv_iter loop gets stuck. As a results the gui is not responding, and I can not change the value of the biases and the roi.
Is there a way so the mv_iter loop continue even when no events got received from the camera?
