I have set up the IMX636 with the kria board via usb (uart connection) and also it is conenct via ethernet to the router, not the laptop directly since I have no possibility to do this, nevertheless I can ssh into the device no issue or via serial interface.
Via ssh i run
- V4L2_HEAP=reserved V4L2_SENSOR_PATH=/dev/v4l-subdev3 metavision_viewer
and it opens the metavision viewer without issues. But when I try it via serial with
- Xorg &
- DISPLAY=:0.0 V4L2_HEAP=reserved V4L2_SENSOR_PATH=/dev/v4l-subdev3 metavision_viewer
I see no HDMI output without any info, and connecting DP shows:
Feb 3 01:48:59 xilinx-kv260-starterkit-20222 kernel: zynqmp-display fd4a0000.display: failed to configure links
Feb 3 01:48:59 xilinx-kv260-starterkit-20222 kernel: zynqmp-display fd4a0000.display: failed to train the DP lk
And heres the output when I start the metavision viwer:
- Simple viewer to stream events from an event file or a device, using the SDK Stream API.
- Define a region using the cursor (click and drag) to set a Region of Interest (ROI)
- Press SPACE key while running to record or stop recording raw data
- Press 'q' or Escape key to leave the program.
- Press 'o' to toggle the on screen display.
- Press 'l' to load the camera settings from the input camera config file.
- Press 's' to save the camera settings to the output camera config file.
- Press 'r' to toggle the hardware ROI mode (window mode or lines mode, default: window mode).
- Press 'R' to toggle the ROI/RONI mode.
- Press 'S' to toggle the subsampling.
- Press 'e' to toggle the ERC module (if available).
- Press '+' to increase the ERC threshold (if available).
- Press '-' to decrease the ERC threshold (if available).
- Press 'h' to print this help.
- [HAL][INFO] V4l2 Discovery with great success +1
- Plugin used to open the device: hal_plugin_prophesee
- Camera has been opened successfully.
- [HAL][INFO] V4l2DataTransfer - start_impl()
- [HAL][INFO] V4l2DataTransfer - run_impl()
Another hint is that the keyboard attached to the kria works, i.e. if I press h the help screen is streamed to the serial interface and if i press q it also exits it (although some times it works others it doesnt react).
Also this might be interesting:
- root@xilinx-kv260-starterkit-20222:~# xrandr --query
Can't open display
