OnDemandFrameGeneration Segmentation Fault and malloc error
I have run into a problem with the OnDemandFrameGeneration algorithm when encountering high event rates. Currently we are making our own multi-event camera calibration program (to calibrate intrinsics and extrinsics in one pass) and I found the OnDemandFrameGeneration algorithm to be suitable. However, it seg faults with a high event rate. I'm unsure if this is a problem with how I'm using it or not, but I have attached a minimal example. Additionally, it sometimes doesn't seg fault but instead produces a "double free or corruption (out)" error.
I have attached the code to reproduce this in minimal_example.cpp, my platform info in platform_info.txt, and the stack trace (obtained using backward-cpp) in stack_trace.txt. I am using OpenCV 4.2.0
Currently, I plan to forego using OnDemandFrameGeneration to get around this problem, but if I am simply making a mistake somewhere then it would be ideal if I could continue using it.
