Stereo Calibration Depth Mapping
Hi, I am trying to use the metavision_stereo_metavision.py script to create a depth map using two syncronized recordings obtained from the metavision_sync.py script but when I run the script I get a lot of NonMontonicTimeHigh and InvalidVectBase errors with the following window thats attached in the image. The depth map isnt produced at all and I cant see the 2 video streams while the stereo script is running. I did use the base calibration.json file that was available as an example and didnt get the calibration settings for my cameras yet so im wondering if thats just the issue. If so, could you provide me with information on how to get the calibration settings for my cameras?
