train_detection script not training properly (Warning: No boxes were added to the evalutaion)
I am trying to use the train_detection.py script to train the model used the public FRED dataset (https://miccunifi.github.io/FRED/). I put the data in the correct structure but when I start training, every epoch displays the messaage:
Warning : No boxes were added to the evaluation !
and all of the metrics are -1 throughout each epoch. Im not sure what this message is referring to as I placed all of the h5 files and their associated npy files in the correct directory. Here is how my dataset is structured:
-dataset
label_map_dictionary.json
 --train
  events_0.h5
  events_1.h5
  events_2.h5
  events_3.h5
  events_0_bbox.npy
  events_1_bbox.npy
  events_2_bbox.npy
  events_3_bbox.npy
 --val
  events_4.h5
  events_5.h5
  events_6.h5
  events_7.h5
  events_4_bbox.npy
  events_5_bbox.npy
  events_6_bbox.npy
  events_7_bbox.npy
I am running with a batch size of two, here is the output during training. Any help would be appreciated.
/home/allen/.pyenv/versions/metavision/lib/python3.10/site-packages/lightning_fabric/connector.py:571: `precision=16` is supported for historical reasons but its usage is discouraged. Please set your precision to 16-mixed instead!
Using 16bit Automatic Mixed Precision (AMP)
GPU available: True (cuda), used: True
TPU available: False, using: 0 TPU cores
HPU available: False, using: 0 HPUs
`Trainer(limit_train_batches=1.0)` was configured so 100% of the batches per epoch will be used..
`Trainer(limit_val_batches=1.0)` was configured so 100% of the batches will be used..
`Trainer(limit_test_batches=1.0)` was configured so 100% of the batches will be used..
You are using a CUDA device ('NVIDIA RTX 4000 Ada Generation Laptop GPU') that has Tensor Cores. To properly utilize them, you should set `torch.set_float32_matmul_precision('medium' | 'high')` which will trade-off precision for performance. For more details, read https://pytorch.org/docs/stable/generated/torch.set_float32_matmul_precision.html#torch.set_float32_matmul_precision
2025-11-11 15:07:18.461175: I tensorflow/core/util/port.cc:153] oneDNN custom operations are on. You may see slightly different numerical results due to floating-point round-off errors from different computation orders. To turn them off, set the environment variable `TF_ENABLE_ONEDNN_OPTS=0`.
2025-11-11 15:07:18.499993: I tensorflow/core/platform/cpu_feature_guard.cc:210] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: AVX2 AVX_VNNI FMA, in other operations, rebuild TensorFlow with the appropriate compiler flags.
2025-11-11 15:07:19.500305: I tensorflow/core/util/port.cc:153] oneDNN custom operations are on. You may see slightly different numerical results due to floating-point round-off errors from different computation orders. To turn them off, set the environment variable `TF_ENABLE_ONEDNN_OPTS=0`.
LOCAL_RANK: 0 - CUDA_VISIBLE_DEVICES: [0]
No Learning Rate Scheduler
/home/allen/.pyenv/versions/metavision/lib/python3.10/site-packages/pytorch_lightning/utilities/model_summary/model_summary.py:231: Precision 16-mixed is not supported by the model summary.  Estimated model size in MB will not be accurate. Using 32 bits instead.
  | Name     | Type                | Params | Mode
0 | detector | SingleStageDetector | 24.1 M | train
24.1 M    Trainable params
0         Non-trainable params
24.1 M    Total params
96.297    Total estimated model params size (MB)
108       Modules in train mode
0         Modules in eval mode
Sanity Checking: |                                                       | 0/? [00:00<?, ?it/s]/home/allen/.pyenv/versions/metavision/lib/python3.10/site-packages/metavision_ml/data/scheduler.py:193: RuntimeWarning: overflow encountered in scalar negative
  excess_duration[mask] = duration[mask] % - total_tbins_delta_t
Sanity Checking DataLoader 0:   0%|                                      | 0/2 [00:00<?, ?it/s]/home/allen/.pyenv/versions/metavision/lib/python3.10/site-packages/torch/functional.py:554: UserWarning: torch.meshgrid: in an upcoming release, it will be required to pass the indexing argument. (Triggered internally at /pytorch/aten/src/ATen/native/TensorShape.cpp:4322.)
  return _VF.meshgrid(tensors, **kwargs)  # type: ignore[attr-defined]
Sanity Checking DataLoader 0: 100%|██████████████████████████████| 2/2 [00:00<00:00,  2.31it/s]==> Start evaluation
mean_ap75 :  -1.0
mean_ar_medium :  -1.0
mean_ap50 :  -1.0
mean_ap_big :  -1.0
mean_ap :  -1.0
mean_ap_small :  -1.0
mean_ap_medium :  -1.0
mean_ar_big :  -1.0
mean_ar_small :  -1.0
mean_ar :  -1.0
Epoch 0: 100%|██████████████████████████████████████| 581/581 [01:58<00:00,  4.88it/s, v_num=1==> Start evaluationer 0: 100%|███████████████████████████████| 583/583 [02:15<00:00,  4.29it/s]
mean_ap75 :  -1.0
mean_ap50 :  -1.0
mean_ap_big :  -1.0
mean_ap :  -1.0
mean_ar_big :  -1.0
mean_ar :  -1.0
Epoch 1: 100%|██████████████████████████████████████| 581/581 [02:03<00:00,  4.69it/s, v_num=1==> Start evaluationer 0: 100%|███████████████████████████████| 583/583 [02:19<00:00,  4.17it/s]
mean_ap75 :  -1.0
mean_ap50 :  -1.0
mean_ap_big :  -1.0
mean_ap :  -1.0
mean_ar_big :  -1.0
mean_ar :  -1.0
Epoch 2: 100%|██████████████████████████████████████| 581/581 [02:05<00:00,  4.63it/s, v_num=1==> Start evaluationer 0: 100%|███████████████████████████████| 583/583 [02:22<00:00,  4.09it/s]
mean_ap75 :  -1.0
mean_ap50 :  -1.0
mean_ap_big :  -1.0
mean_ap :  -1.0
mean_ar_big :  -1.0
mean_ar :  -1.0
