Using OpenEB on Raspberry Pi 5
i'm running into a problem when trying to use the EVK3 on my Raspberry Pi 5.
I compiled from source and even used ctest to verify the functionality.
But when i try to launch for example metavision_viewer i get the following error:
  1. [HAL][ERROR] Failed to build streaming facilities : ioctl: VIDIOC_DBG_G_REGISTER failed to read register
    [HAL][INFO] V4l2 Discovery failed with horrible failure -1
    Metavision SDK Driver exception
    Error 101001: Camera not found. Check that a camera is plugged on your system and retry.
The camera is attached and metavision_plattform_info gives me the following output:
  1. ------------------------------------------
    PLATFORM INFORMATION
    ####  DISTRIBUTION  ####
    Linux fe-recorder 6.6.31+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
    ####  OPENGL  ####
    sh: 1: glxinfo: not found
    Failed to retrieve OpenGL information
    ####  VIRTUAL MACHINE  ####
    Virtual Machine:                                  NO
    Docker:                                           NO
    METAVISION SOFTWARE INFORMATION
    ####  INSTALLED SOFTWARE  ####
    Version:                                          4.6.0
    ####  INSTALLED PACKAGES - METAVISION  ####
    Failed to retrieve installed Metavision packages list
    METAVISION SYSTEMS INFORMATION
    ####  SYSTEMS AVAILABLE  ####
    ## Prophesee Gen4.1 HD ##
    # System information
    Available Data Encoding Formats                   EVT3,EVT21
    Connection                                        USB
    Current Data Encoding Format                      EVT3
    EVK3 Build Date                                   Fri Oct  7 14:41:28 2022
    EVK3 Release Version                              3.9.0
    EVK3 Speed                                        5000
    Integrator                                        Prophesee
    Sensor Name                                       Gen4.1
    Serial                                            *****
    SystemID                                          48
    device0 compatible                                psee,ccam5_gen41
    device0 name                                      CCam5 Gen41 Event-Based Camera
    device1 compatible                                ti,tmp103
    device1 name                                      Temperature sensor
    # Available device config options
    format                                            default: EVT3 values: EVT21 | EVT3
    ll_biases_range_check_bypass                      default: 0 values: true | false
    # Default Biases
    bias_diff                                         80
    bias_diff_off                                     52
    bias_diff_on                                      115
    bias_fo                                           74
    bias_hpf                                          0
    bias_refr                                         68
    Connection                                        USB
    EVK3 Speed                                        5000
    Sensor Name                                       Gen4.1
    Serial                                            ******
    SystemID                                          48
    # Default Biases
    bias_diff                                         80
    bias_diff_off                                     52
    bias_diff_on                                      115
    bias_fo                                           74
    bias_hpf                                          0
    bias_refr                                         68
    ####  SYSTEM'S USB PORTS  ####
    USB Port type used:                               3.00
It is a fresh installation of raspbian and the device worked on the RPi4.
Does someone know what the problem is?
Cheers and Thanks
G.
Edit:
Here the Log with Trace enabled:
    ####  OPENGL  ####
    OpenGL vendor string: Broadcom
    OpenGL renderer string: V3D 7.1
    OpenGL core profile version string: 3.1 Mesa 23.2.1-1~bpo12+rpt3
    OpenGL core profile shading language version string: 1.40
    OpenGL core profile context flags: (none)
    OpenGL core profile extensions:
    OpenGL version string: 3.1 Mesa 23.2.1-1~bpo12+rpt3
    OpenGL shading language version string: 1.40
    OpenGL context flags: (none)
    OpenGL extensions:
    OpenGL ES profile version string: OpenGL ES 3.1 Mesa 23.2.1-1~bpo12+rpt3
    OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
    OpenGL ES profile extensions:
    Virtual Machine:                                  NO
    Docker:                                           NO
    Version:                                          4.5.2
    [HAL][TRACE] Listing cameras of any type
    [HAL][TRACE] Loading plugins
    [HAL][TRACE]   Setting up search paths
    [HAL][TRACE]     Adding plugin search path: /usr/local/lib/metavision/hal/plugins
    [HAL][TRACE]   Loading plugins...
    [HAL][TRACE]     [hal_plugin_prophesee] (Prophesee) 3 camera discoveries 1 file discoveries
    [HAL][TRACE]   Found 1 plugins
    [HAL][TRACE]   Plugin [hal_plugin_prophesee] (Prophesee)
    [HAL][TRACE] EVK1 libusb BC: libusb_get_device_list found 6 devices
    [HAL][TRACE] EVK1 libusb BC: PSEE device found
    [HAL][TRACE] FPGA is properly configured
    [HAL][TRACE] Released interface
    [HAL][TRACE] Reset device
    [HAL][TRACE]     Camera discovery Metavision::Fx3CameraDiscovery does not recognize any device
    [HAL][TRACE] libusb BC: libusb_get_device_list found 6 devices
    [HAL][TRACE] Claimed interface 0 of EVK3
    [HAL][TRACE] Create board command for EVK3 *****( 4b4 : f4 )
    [HAL][TRACE] EVK3 has 2 Treuzell devices
    [HAL][TRACE] CCam5 Gen41 Event-Based Camera is compatible with psee,ccam5_gen41
    [HAL][TRACE] Got 2 build method(s) for CCam5 Gen41 Event-Based Camera
    [HAL][TRACE] Temperature sensor is compatible with ti,tmp103
    [HAL][TRACE] Got 2 build method(s) for Temperature sensor
    [HAL][TRACE] Register board command for EVK3 *****( 4b4 : f4 )
    [HAL][TRACE] Released interface 0 on EVK3
    [HAL][TRACE]     Camera discovery Metavision::TzCameraDiscovery recognizes:
    [HAL][TRACE]       Serial: 00042346
    [HAL][TRACE]     Camera discovery Metavision::V4l2CameraDiscovery recognizes:
    [HAL][TRACE]       Serial: v4l2_device
    [HAL][TRACE] Opening camera with serial: Prophesee:hal_plugin_prophesee:****
    [HAL][TRACE]   MV_HAL_PLUGIN_PATH did not change and plugins are already loaded, no need to reload plugins
    [HAL][TRACE]   Plugin [hal_plugin_prophesee] (Prophesee) matches the serial
    [HAL][TRACE]         -> cannot open the serial
    [HAL][TRACE] Dev 0 name: CCam5 Gen41 Event-Based Camera
    [HAL][TRACE] Gen41 ERC Init
    [HAL][TRACE] Dev 1 name: Temperature sensor
    [HAL][TRACE] Data Transfer: Try to flush
    [HAL][TRACE] Total of  0  bytes flushed
    [HAL][TRACE]         -> can open the serial
    Connection                                        USB
    EVK3 Speed                                        5000
    Sensor Name                                       Gen4.1
    Serial                                            *****
    SystemID                                          48
    # Default Biases
    bias_diff                                         80
    bias_diff_off                                     52
    bias_diff_on                                      115
    bias_fo                                           74
    bias_hpf                                          0
    bias_refr                                         68
    [HAL][TRACE] Opening camera with serial: Prophesee:hal_plugin_prophesee:v4l2_device
    [HAL][TRACE] Create board command for EVK3 ******( 4b4 : f4 )
    [HAL][TRACE] Register board command for EVK3 ******( 4b4 : f4 )
    [HAL][TRACE] V4l2Discovery - Discovering...
    [HAL][ERROR] Failed to build streaming facilities : ioctl: -VIDIOC_DBG_G_REGISTER failed to read register
