Biases pre-sets
Biases pre-sets
Prophesee Event-Based sensors can be tuned for optimal functioning in a specific applications and in a particular environment condition by adjusting the sensor settings so-called biases.
On this page we provide several biases pre-sets for different applications. These pre-sets should be seen as a starting point for bias tuning for a particular application and not as a final solution. The final solution will depend on many factors and here we provide only a generic idea.
Biases pre-sets for GenX320 MP sensor
ApplicationSpeedbias_diffbias_diff_offbias_diff_onbias_fobias_hpfbias_refrWhat is seen
Min recommended*Low4119241900
Max recommended*High51506039127127
Default*Medium512825344010
Moving / changing objects
Low-light detectionLow51192419010Moving / changing objects
Drone tracking
Medium
51
40
40
29
0
82
High-speed motion,
Object counting,
PSM (Particle Size Measurement)
High512637387425Fast moving objects
LED tracking**High51455550**1270High-frequency LED only
Active marker detection**High51127**78**50**1270Active marker only
* Based on Metavision SDK v5.x
** Outside of the recommended range
Biases pre-sets for IMX636 sensor
Info
Please note that all IMX636 sensors are individually trimmed during the manufacturing process, resulting in sensor-specific factory biases settings. In Metavision SDK, all relative biases are set to 0 by default, but these values correspond to different absolute biases settings depending on the sensor.
Factory biases settings can be found in the log when the log level is set to TRACE. As factory settings can vary between sensors, the amount of background activity observed in a static dark scene may also vary.
The biases pre-sets below should therefore be considered as examples of relative biases settings. Their effect depends on the sensor's factory settings, and additional adjustments may be required for optimal results.
Min recommended*Low-25-35-85-350-20
Max recommended*High2319014055120235
Default*Medium000000Moving/changing objects
High-speed motion,
Object counting,
High01650551100Fast moving objects
Active marker detection**High01806030140**0Active marker only
Applying the biases pre-sets
Each biases pre-set can be downloaded as a *.bias or *.json file from the attachments to this page.
Each biases pre-set can be applied in one of the following ways:
  1. via a command line option "-j" followed by a *.json configuration file:
    1. metavision_viewer -j genx320_lowlight.json
  2. via a command line option "-b" followed by a *.bias file:
    1. metavision_viewer -b genx320_lowlight.bias
  3. in the code using Metavision API (in C++ or Python)
