EVK3 - GenX320 - Product Brief
Prophesee Evaluation Kit 3 (EVK3) enables fast, cost-efficient first hands-on evaluation of Prophesee’s Event-Based Vision. It is available for GenX320 sensor and delivered with an USB cable.
Notes
- Note that EVK3 is delivered without casing.
- Regarding the EVK3 GenX320, If you plan to use the ULP modes, you should go for GenX320 CM2 module as it exposes the ULP I/Os directly in addition to each sensor power supply.
Therefore, the sequence to enter ULP mode, as found in the datasheet, can be followed
Idea
You can access EVK3 camera manual when you are logged in with your Knowledge Center account.
If you are Prophesee customer, you can request your account.
List of attachments:
- EVK3_Prophesee_Evaluation_Kit_Product_Brief_GenX320_CM2.pdf
- EVK3_Prophesee_Evaluation_Kit_Product_Brief_GenX320_COB.pdf
