EVK3 - VGA/320/HD - Product Brief
Prophesee Evaluation Kit 3 (EVK3) enables fast, cost-efficient first hands-on evaluation of Prophesee’s Event-Based Vision. It is available in multiple versions, featuring our VGA sensor, our GenX320 sensor or our HD sensor co-developed with Sony Semiconductor Solutions. It is delivered with USB cables.
- Note that EVK3 is delivered without casing.
- Regarding the EVK3 GenX320, If you plan to use the ULP modes, you should go for GenX320 CM2 module as it exposes the ULP I/Os directly in addition to each sensor power supply.
Therefore, the sequence to enter ULP mode, as found in the
datasheet, can be followed
You can access
EVK3 camera manual when you are logged in with your Knowledge Center account.
List of attachments:
- EVK3_Prophesee_Evaluation_Kit_Product_Brief_VGA.pdf
- EVK3_Prophesee_Evaluation_Kit_Product_Brief_HD.pdf
- EVK3_Prophesee_Evaluation_Kit_Product_Brief_GenX320_CM2.pdf
- EVK3_Prophesee_Evaluation_Kit_Product_Brief_GenX320_COB.pdf
As a Prophesee customer, get access to your personal ticketing tool, application notes, product manuals, SDK Download Center and more resources.
