EVK4 - HD - Product Brief
Start your event-based vision exploration with prophesee EVK4 HD. The ultra-light and compact, HD Metavision Evaluation Kit built to endure field testing conditions.
Product brief can be downloaded in the attachments at the bottom of this page.
HIGHLIGHTS
• HD Resolution (1280x720 pixels)
• Synchronization interface
• High-Quality Aluminum alloy casing - 30x30x36mm - 40g
• IEC certifications (T° / Heat / Shocks / Electrostatic discharge)
• Easy to use USB 3.0 type-C connectivity
• C/CS mount
• Soyo SFA0820-5M lens (see lens datasheet and Soyo Lens List)
You can access EVK4 camera manual when you are logged in with your Knowledge Center account.
If you are Prophesee customer, you can request your account.
A training video on Unboxing EVK4 is available
