How to set biases and record a RAW file using Python
Our samples metavision_viewer.cpp and metavision_hal_view.cpp show how to use C++ to set biases and record "raw data" in a .raw file  by means of a PROPHESEE camera.
Those samples  allow to save bias paramaters in a .bias file as well.
In this page you will find a Python code showing how to achieve the same operations using Python3x.
This piece of code is inspired of Metavision recorder with provide additional set of feature through a GUI interface (monitoring event rate, enable hardware filters etc...).
If needed, a batch version of the recorder is also available on the recorder KC page.
    As a Prophesee customer, get access to your personal ticketing tool, application notes product manuals and more resources.
