Sensor's Quantum Efficiency / Spectral Response
The Quantum Efficiency (QE) is derived from the LIFO (Light Input Frequency Output) feature of the sensor.
Note that the LIFO must be calibrated and this calibration is done via a dedicated pin not accessible on EVKs
Here we share some indicative values about results found for each of our sensor's generation.
Official values should be retrieved from the Datasheet but those values give you a first idea on our sprectral response.
Quantum Efficiency for Gen31, Gen40 and Gen41:
LED Wavelength
455nm505nm625nm850nm940nm
Gen31
37%
39%
37%
15%
5%
Gen40
42%
52%
52%
23%
11%
Gen41
60%
78%
69%
28%
13%
Relative Spectral Response for IMX636 and IMX646
LED Wavelength455nm505nm625nm850nm940nm
IMX636/IMX64688%100%92%39%18%
Note: this table is relative to the wavelength that has the higher response (505nm)
Quantum Efficiency for GenX320 (preliminary results)
LED Wavelength
365 nm
455nm
530 nm
590nm625nm850nm940nm
1050 nm
GenX320
58 %
89%
94%
87%84%43%20 %
5 %
