Starter Kit – Raspberry Pi 5 (GenX320) - Software update
If you installed the system using our custom image and wish to update the sensor driver to the latest version, please follow the steps below:
1. Remove the existing driver:
  1. Check the currently installed version:
  1.  sudo dkms status
  1. Uninstall and remove the current version (replace <current_version> with the actual version, e.g., 1.0):
  1. sudo dkms uninstall psee_sensor_drivers/<current_version>
  2. sudo dkms remove psee_sensor_drivers/<current_version>
2. Get the driver source:
  1. git clone https://github.com/prophesee-ai/rpi-sensor-drivers.git
3. Build the driver:
  1. cd rpi-sensor-drivers
  2. make prepare
  3. make
4. Install the driver using DKMS (replace <new_version>, e.g., 1.0.1):
  1. sudo dkms add .
  2. # It will return the <new_version>
  3. sudo dkms build psee_sensor_drivers -v <new_version>
  4. sudo dkms install psee_sensor_drivers -v <new_version>
