OpenMV Cam
OpenMV Cam
OpenMV GENX320 Event Camera Module makes Prophesee GenX320 sensor compatible and ready to be used with compact, Python-powered, machine vision embedded platforms such as
  1. OpenMV Cam H7 Plus (recommended)
  2. OpenMV N6
  3. OpenMV Cam RT1062
OpenMV Cam H7 Plus with GENX320 Event Camera Module
Data are transmitted from the sensor via a low-power and low latency CMOS Parallel Interface (CPI).
OpenMV platform is provided with an open-source driver and OpenMV IDE. However, it is not supported by Metavision SDK.
Key Features
  • Based on micro-controllers:
    • OpenMV Cam H7 Plus - STM32 H7 Plus micro-controller
    • OpenMV Cam N6 - STM32 N6 micro-controller
    • OpenMV Cam RT1062 - NXP RT1062 micro-controller
  • Streams CD events or event histograms natively from GenX320 sensor
    • In event mode
      • Max frame rate on OpenMV Cam H7 Plus (with 2048 buffer size) is 1000 fps (without visualization) and 500fps (with visualization)
    • In histogram mode (Diff3D algorithm)
      • Max event histogram rate on OpenMV Cam H7 Plus is 375 fps
      • Max event histogram rate on OpenMV Cam RT1062 is 180 fps
  • Includes a set of machine learning and image processing algorithms and examples
  • Small form factor camera expandable via shield add-ons
Supported boards
  2. OpenMV Cam RT1062
  3. OpenMV N6
Supported SW
Supported sensors and settings
Supported sensor modules:
Supported sensor data formats:
  • Contrast Detection (CD) pixels events streamed in EVT2.0 format and output as NumPy ndarray arrays.
    • Output Ndarray holds
      • # 0: event type
      • # 1: seconds timestamp
      • # 2: milliseconds timestamp
      • # 3: microseconds timestamp
      • # 4: x coordinate (0-319)
      • # 5: y coordinate (0-319)
  • Event histograms built on-sensor in Diff3D format and output as images.
    • The histograms are built on-sensor by accumulating Contrast Detection (CD) pixels events over a chosen “integration/accumulation period”
    • Output data are formatted as 2D images with a resolution of 320×320 pixels, each represented as 8-bit values
Supported sensor settings:
  • Sensor biases
  • Event Signal Processing (ESP) filters
  • Low Power Mode (PM2) allowing to reduce consumption whilst maintaining quick wake-up based on scene dynamics can be activated by sensor.sleep function
  • Further sensor features can be configured by writing/reading registers (note that the read/write command accepts 16-bit values only)
Installation
  1. Install OpenMV IDE
  2. (optional) Clone and compile OpenMV firmware if you want to do low-level changes in the driver and re-flash the board
Getting Started
  • Plug the OpenMV Cam to USB port on your PC
  • Start OpenMV IDE
  • Connect to the camera and install the latest firmware from the menu "Tools / Install the Latest Development Release"
  • Run ready-to-use examples from the menu "File / Examples / Camera / GenX320"
How to do changes in the firmware and flash it?
If you want to do low-level changes in the firmware, it is possible as it is open source.
  1. Get the firmware from https://github.com/openmv/openmv
    1. git clone git@github.com:openmv/openmv.git
    2. cd openmv
    3. do changes in the code
  2. Compile the firmware with the docker (easiest way)
    1. make clean
    2. cd docker
    3. Compile the firmware for the target board (see the supported boards mentioned earlier), here is an example for H7 Plus
      1. make TARGET=OPENMV4P
  3. Flash the board with the compiled firmware
    1. Open OpenMV IDE
    2. Click “Tools/Run Bootloader (Load firmware)” or press Ctrl+Shift+L
    3. Select the compiled “firmware.bin” (from openmv/docker/build/”board”/bin/ folder) and click “Run“ button (if you occasionally chosen the firmware for a wrong board then it is more difficult to re-flash it)
    4. Do not disconnect the board until it is finished flashing
  4. You are ready to work with the new firmware
  5. Run example scripts from https://github.com/openmv/openmv/tree/master/scripts/examples/01-Camera/03-Event-Cameras/02-Genx320
Examples
There are several examples that comes with the firmware. They can be opened and started from OpenMV IDE.
Minimal example of histogram streaming
This minimal example shows how to acquire event histograms from the sensor, visualize them and print the output histogram rate.
  1. import sensor
    import time
    sensor.reset() # Initializes the sensor.
    sensor.set_pixformat(sensor.GRAYSCALE) # Must always be grayscale.
    sensor.set_framesize(sensor.B320X320) # Must always be 320x320.
    sensor.set_framerate(100)
    clock = time.clock()
    while True:
    clock.tick()
    img = sensor.snapshot()
    print(clock.fps())
Minimal example of event streaming
This example shows how to acquire CD events, visualize them as a histogram and print the output rate.
  1. import sensor
    import image
    import time
    from ulab import numpy as np
    # Surface to draw the histogram image on.
    img = image.Image(320, 320, sensor.GRAYSCALE)
    # ndarray to hold events from the camera
    # must be EVT_res events by 6 values
    # 0: event type
    # 4: x coordinate (0-319 for the genx320)
    # 5: y coordinate (0-319 for the genx320)
    events = np.zeros((2048, 6), dtype=np.uint16)
    # Initialize the sensor.
    sensor.reset()
    sensor.set_framesize(sensor.EVT_2048)  # Must be EVT_1024/2048/.../65536
    while True:
        clock.tick()
        # Reads up to 2048 events from the camera.
        # Returns the number of valid events (0-2048) or a negative error code.
        # Note that old events in the buffer are not cleared to save CPU time.
        event_count = sensor.ioctl(sensor.IOCTL_GENX320_READ_EVENTS, events)
        # Draws the events on the image. If clear=True then the image is cleared
        # to the default value of "brightness". Event histogram bins have "contrast"
        # added to them for PIX_ON_EVENT events and subtracted from them for
        # PIX_OFF_EVENT events clampped between 0 and 255. Pass clear=False to keep
        # accumulating events in the histogram image.
        img.draw_event_histogram(events[:event_count], clear=True, brightness=128, contrast=64)
        # Push the image to the jpeg buffer for the IDE to pull and display.
        # The IDE pulls frames off the camera at a much lower rate than the
        # onboard camera frame rate printed below.
        img.flush()
        print(event_count, clock.fps())
Example of LED tracking based on histogram data
This example shows how to stream histograms, apply a preset of sensor biases tuned for seeing only high-frequency LEDs and track LEDs.
  1. import sensor
    import time
    sensor.reset()
    sensor.set_framerate(200)
    sensor.ioctl(sensor.IOCTL_GENX320_SET_BIASES, sensor.GENX320_BIASES_ACTIVE_MARKER) # Applies sensor biases for seeing LEDs only
    while True:
    clock.tick()
    blobs = img.find_blobs(
    [(120, 140)], invert=True, pixels_threshold=2, area_threshold=4, merge=True
    for blob in blobs:
    img.draw_rectangle(blob.rect(), color=(255, 255, 255))
    img.draw_cross(blob.cx(), blob.cy(), color=(0, 0, 0))
    print(clock.fps())
Example of biases tuning
This example shows how to stream histograms and tune individual sensor biases one by one.
  1. import sensor
    import time
    sensor.reset()
    sensor.set_framerate(400)
    sensor.ioctl(sensor.IOCTL_GENX320_SET_BIAS, sensor.GENX320_BIAS_DIFF_OFF, 28)
    sensor.ioctl(sensor.IOCTL_GENX320_SET_BIAS, sensor.GENX320_BIAS_DIFF_ON, 25)
    sensor.ioctl(sensor.IOCTL_GENX320_SET_BIAS, sensor.GENX320_BIAS_FO, 34)
    sensor.ioctl(sensor.IOCTL_GENX320_SET_BIAS, sensor.GENX320_BIAS_HPF, 40)
    sensor.ioctl(sensor.IOCTL_GENX320_SET_BIAS, sensor.GENX320_BIAS_REFR, 10)
    while True:
    clock.tick()
    print(clock.fps())
Example of AFK setting
This example shows how to stream histograms and set AFK filter to filter out a given range of frequencies.
  1. import sensor
    import time
    sensor.reset()
    # Enables AFK filter to remove periodic data in the frequency range from 130Hz to 160Hz
    sensor.ioctl(sensor.IOCTL_GENX320_SET_AFK, 1, 130, 160)
    # Disables AFK filter
    # sensor.ioctl(sensor.IOCTL_GENX320_SET_AFK, 0)
    while True:
        clock.tick()
        print(clock.fps())
To buy an OpenMV Cam with GENX320 Event Camera Module, contact OpenMV.
